Another question that maybe is not worth creating another topic for:
When I enable 'Show portal on all pages', it does not show on all pages...
What is the reason for this? I cleared all the cache.
- phpBB.de User: Kirk
Re: Show portal on all pages
I have a new topic created.
On which pages is it not displayed?
On the forum itself it is not displayed.
The left and right column is activated?
ACP/Extensions/Portal Administration
Only the left because I don't use the right.
Did you set it correctly?
Yes, exactly the same.
Do you use this customized version?
http://reyno41.bplaced.net/phpbb/viewto ... f=33&t=228
Did you change something on the style?
Yes.
I only changed the header image and added advertising banners.
Deactivate the portal extension, delete all associated files via FTP.
Upload the customized version and empty the forums and browser cache.
Okay.
Btw: is it possible to use tapatalk with portal installed?
With tapatalk there were problems with you.
I reinstalled everything but it still won't show the portal on all pages.
Did you install more extension?
