board3 installation problem on phpbb3 3.2.1
boldherri
phpBB.com User: boldherri
Post by boldherri »
Hello everybody
I installed the board3 portal extension on my forum 3.2.1, but when I click on the portal link I get this error page, can someone help me please? I do not know what to do.
I cleaned and deleted cookies abd cache many times but it does not change
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Renderer.php on line 20: DOMDocument::loadXML(): Premature end of data in tag SIZE line 1 in Entity, line: 1
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/s9e/text-formatter/src/Renderer.php on line 20: DOMDocument::loadXML(): Premature end of data in tag r line 1 in Entity, line: 1
Catchable fatal error: Argument 1 passed to s9e_renderer_bfad656d3d6a4a134fc8fe9a75cf2f60d2031dd3::at() must be an instance of DOMNode, null given, called in /membri/nightfury/forum/cache/production/s9e_renderer_bfad656d3d6a4a134fc8fe9a75cf2f60d2031dd3.php on line 31 and defined in /membri/nightfury/forum/cache/production/s9e_renderer_bfad656d3d6a4a134fc8fe9a75cf2f60d2031dd3.php on line 34
Solidjeuh
phpBB.com User: Froddelaar
Re: board3 installation problem on phpbb3 3.2.1
Post by Solidjeuh »
Seems to be a PHP problem, you use PHP 7.1.x ?
Running here on PHP 7.2.3 without a problem
Register a free account & Play!!
~~~ https://www.solidjeuh.be ~~~
Have a secret? --> https://www.tellyoursecrets.eu
boldherri
Post by boldherri »
Solidjeuh wrote: 21. June 2018 21:30 Seems to be a PHP problem, you use PHP 7.1.x ?
Hello Solid
No I'm using PHP 5.6.34
the extension installs correctly, but when I click on the portal link it gives me that error page
I can not solve unfortunately
Solidjeuh
Post by Solidjeuh »
boldherri
Post by boldherri »
Solidjeuh wrote: 23. June 2018 03:32 I searched phpBB and found:
https://www.phpbb.com/community/viewtop ... #p14770826
Did you install the Board3 Portal for phpBB 3.2?
My updated files:
https://www.muziekpromo.net/scripts/board3.zip
Or:
http://reyno41.bplaced.net/phpbb/viewto ... t=228#p898
Hi Solid, thank you for your help
I tried them but unfortunately I have the same error, it's incredible.
I checked as the error says in this file s9e_renderer_...... on line 31 i have this code
$this->at($dom->documentElement);
and in line 34 have this
protected function at(\DOMNode $root)
for this post https://www.phpbb.com/community/viewtop ... #p14770826 I did not understand in which template to make the change
I replaced <br> by <br/> and it is now ok.
if I do not solve I'll try again after updating to my phpbb3 3.2.3
Solidjeuh
Post by Solidjeuh »
Ok, go to Extensions - Portal Modules - Latest news module
And change "Compact news block style:" to YES
I think the problem is there..
boldherri
Post by boldherri »
Solidjeuh wrote: 24. June 2018 16:00 Ok, go to Extensions - Portal Modules - Latest news module
Hello Solid,
the module Latest news module in Compact news block style it's already set to yes, I also tried to put on no but it does not change
and nothing, I give up at the moment, waiting for an update of the extension.
thank you so much for your help,
