Option to hide/show the nav-bar on the portal page?
Bermudez
phpBB.com User: Bermudez
Post by Bermudez »
Hello.
It would be interesting to have an option in the administration panel to hide/show the nav-bar on the portal page.
Or alternatively, what should I edit to get it?
Regards.
Re: Option to hide/show the nav-bar on the portal page?
in the ACP it is not possible.
There is still a possibility I have to test first. It can take a while.
Bermudez
Post by Bermudez »
Thank you.
I will wait patiently.
Bermudez wrote: 20. November 2017 11:47 Hello.
If you hide the nav-bar in the portal, it becomes cumbersome if a user wants to log in via the portal in the smartphone, because then the login block is moved to far below.
And furthermore, other menus are also hidden for quick access in the portal. ;)
Create a file with the name overall_header_portal.html copy the code in the root/styles/prosilver/template/overall_header.html into this new file.
Find and delete this in the new file <!-- INCLUDE navbar_header.html -->
Upload this file to root/ext/board3/portal/styles/prosilver/template
Open: root/ext/board3/portal/styles/prosilver/template/portal/portal_body.html
Find:
Replace with:
<!-- INCLUDE overall_header_portal.html -->
In the end "ACP -> General" --> purge cache
Bermudez
Post by Bermudez »
Many thanks!
Done!
HoodieWeather
Post by HoodieWeather »
Bermudez wrote: 24. November 2017 17:09 Many thanks!
Done!
What's your site, so i can check it out, before I do mind. If, I want to .
Bermudez
Post by Bermudez »
HoodieWeather wrote: 17. January 2018 12:38
Done!
https://ferrosim.es/
HoodieWeather
Bermudez wrote: 17. January 2018 19:20
Done!
looks good
Bermudez
Post by Bermudez »
Thanks!
