Sql error during activation?
charliee
Post by charliee » 11. April 2017 00:27
Hi, i got the not so funny task to clean up a phpbb forum, it used to run phpbb 3.0.11 until some dummy upgraded it without uninstalling any mods so its a bit broken, got rid of most of the old junk and in the process of installing some extentions, board3 looked like a nice clean portal but when i try to activate it i get a sql error.
Is this a board3 or phpbb related error?
Regards
Charlie
General Error
SQL ERROR [ mysqli ]
Table 'plloshie_se.phpbb3_portal_modules' doesn't exist [1146]
SQL
SELECT module_id FROM phpbb3_portal_modules WHERE module_classname = '\\board3\\portal\\modules\\clock'
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
FILE: [ROOT]/phpbb/db/driver/driver.php
LINE: 999
CALL: trigger_error()
FILE: [ROOT]/phpbb/db/driver/mysqli.php
LINE: 193
CALL: phpbb\db\driver\driver->sql_error()
FILE: [ROOT]/phpbb/db/driver/factory.php
LINE: 329
CALL: phpbb\db\driver\mysqli->sql_query()
FILE: [ROOT]/ext/board3/portal/migrations/v210_rc1.php
LINE: 36
CALL: phpbb\db\driver\factory->sql_query()
CALL: board3\portal\migrations\v210_rc1->add_clock_setting()
FILE: [ROOT]/phpbb/db/migrator.php
LINE: 711
CALL: call_user_func_array()
LINE: 658
CALL: phpbb\db\migrator->run_step()
LINE: 436
CALL: phpbb\db\migrator->process_data_step()
LINE: 288
CALL: phpbb\db\migrator->try_apply()
LINE: 241
CALL: phpbb\db\migrator->update_do()
FILE: [ROOT]/phpbb/extension/base.php
LINE: 78
CALL: phpbb\db\migrator->update()
FILE: [ROOT]/phpbb/extension/manager.php
LINE: 185
CALL: phpbb\extension\base->enable_step()
FILE: [ROOT]/includes/acp/acp_extensions.php
LINE: 197
CALL: phpbb\extension\manager->enable_step()
FILE: [ROOT]/includes/functions_module.php
LINE: 676
CALL: acp_extensions->main()
FILE: [ROOT]/adm/index.php
LINE: 82
CALL: p_master->load_active()
