Latest news showing strange characters
sbashwar
phpBB.de User: sbashwar
phpBB.com User: sbashwar
Post by sbashwar » 24. February 2017 11:45
Since some compatibility issue with phpBB 3.2 I disabled the Board3 2.1.0 portal.
I updated with modified files on my computer those are available on board3.de. Everything is running fine except Latest news showing strange characters on it. Screen print attached.
https://ibb.co/h2dVfa
Sorry, I could not find a print screen file attachment here.
Solidjeuh
phpBB.com User: Froddelaar
Re: Latest news showing strange characters
Post by Solidjeuh » 24. February 2017 14:21
You need to empty your browser cache, or simply do CTRL F5 on that page.
Normally that should fix it.
Register a free account & Play!!
~~~ https://www.solidjeuh.be ~~~
Have a secret? --> https://www.tellyoursecrets.eu
sbashwar
Post by sbashwar » 25. February 2017 09:13
I did that plus cleared forum caches. The result same.
Solidjeuh
Post by Solidjeuh » 25. February 2017 12:46
This is because the css changed, I see the same questions on phpbb.com
Did you try with another browser?
sbashwar
Post by sbashwar » 25. February 2017 18:46
Yes, I tried it on Firefox & Windows 10 Edge. Same Result.
I tried with Prosilver special edition with no luck.
Solidjeuh
Post by Solidjeuh » 25. February 2017 19:08
Maybe you can try to use my board3 updated files for 3.2:
https://www.board3.de/viewtopic.php?f=7 ... 234#p37234
sbashwar
Post by sbashwar » 28. February 2017 07:53
1.My current updates are from your updated files.
2.I am planning to empty or delete the portal tables from phpMyAdmin and try fresh from your updated files. Any suggestion?
