[RELEASE] Multi-Transition Banner Block V1.0.0
talonos
Portal Specialist
phpBB.com User: talonos
Post by talonos »
Addon: Multi-Transition Banner Module
Addon Version: 1.0.1
Addon Author: Talonos
Addon Description:
This is a Multi-Transition Banner module which is easy to install and configure. it uses 8 images in total. 4 for the banner (they have to be 900px X 325px) and 4 for the thumbnails (they have to be 80px X 65px) just upload your desired images into the 2 folders
{T_THEME_PATH}/images/portal/multibanner/img/large/
{T_THEME_PATH}/images/portal/multibanner/thumb/
then set up your options in the ACP
Options consist of:
choice of 3 Transitions (Fade/Slide/SlideDown)
Enable/Disable the footer portion on the block
Enable/Disable Text Portion on the block
Enable/Disable [More..] Button
Enable/Disable Auto Transition Timer
Adjust Auto Transition Timer
Image filename X4
thumbnail filename X4
Thumbnail Title X4
Thumbnail Description X4
[More..] Button http link X4
Addon Requirements: Board3 Portal 2.0.0b1 and newer.
Download Link is here:
http://pretereo-stormrage.co.uk/viewtopic.php?f=11&t=27
Instructions:
2. Add new module into Top/Bottom OR Center column of the portal (ACP > MODS > Portal > Portal Modules).
Demo: http://pretereo-stormrage.co.uk/portal.php
REVISION INFOMATION
1.0.0
Initial Release
SCREENSHOTS:
