portal redirection after login -please-
Current Version: 2.0.2
Released: 2013-10-27
papicx
phpBB.de User: papicx
phpBB.com User: papicx
Post by papicx »
Your Portal Version: 2.0.1
Boardlink: http://cxclub.org/phpbb/portal.php
nothing
nothing
Hello,
On my forum, when connecting from the portal, it is redirected to the portal. This is what I want.
But if we connect leaving the index.php page, you are redirected to the index.php and I want users to be redirected to the portal page.
I just check the installation of the mod is installed for a long time, and it seems correct.
So I do not know if this is normal and I request a change or if I missed sth. : roll:
thank you in advance for your help
account test: test
Code: Mdp123456
Re: portal redirection after login -please-
Open: root/ucp.php
Find:
    case 'login':
        if ($user->data['is_registered'])
            redirect(append_sid("{$phpbb_root_path}index.$phpEx"));
        login_box(request_var('redirect', "index.$phpEx"));
    break;
Replace with:
    case 'login':
        login_box(request_var('redirect', "portal.$phpEx"));
    break;
Open: root/styles/prosilver/template/index_body.html
Find:
{S_LOGIN_REDIRECT}
Replace with:
<input type="hidden" name="redirect" value="{U_PORTAL}" />
Changes to the templates:
Go to your ACP, choose "Styles -> Templates -> your style", which has been changed and click "refresh" - confirm with "yes".
In the end "ACP -> General" --> purge cache
papicx
Post by papicx »
hello !
Thank you man ! you'r the best :)
papi enjoy
grazia
Post by grazia »
good
