Bad_Company_2_v2
Bad_Company_2_v2
Style: Bad_Company_2_v2
Style Version: 2.0.0
phpBB Version: 3.0.8
Style Download: http://www.awesomestyles.com/phpbb3-sty ... mpany-2-v2
to: styles/Bad_Company_2_v2/template/portal/*.*
to: styles/Bad_Company_2_v2/theme/images/portal/*.*
open: styles/Bad_Company_2_v2/template/breadcrumbs.html
<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> &#187; <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>
open: styles/Bad_Company_2_v2/template/overall_header.html
		<td class="row1">
			<div class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> &#187; <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></div>
<!-- IF S_LOAD_UNREADS --><a href="{U_SEARCH_UNREAD}">{L_SEARCH_UNREAD}</a><!-- IF S_USER_LOGGED_IN --> | <!-- ENDIF --><!-- ENDIF --><!-- IF S_USER_LOGGED_IN --><a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a> | <a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a><!-- ENDIF -->
open: styles/Bad_Company_2_v2/template/portal/block/login_box.html
{$LR_BLOCK_H_L}<!-- IF $S_BLOCK_ICON --><img src="{T_THEME_PATH}/images/portal/portal_login.png" width="16" height="16" alt="" />&nbsp;<!-- ENDIF --><a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a>{$LR_BLOCK_H_R}
{$LR_BLOCK_H_L}<!-- IF $S_BLOCK_ICON --><img src="{T_THEME_PATH}/images/portal/portal_login.png" width="16" height="16" alt="" />&nbsp;<!-- ENDIF -->{L_LOGIN_LOGOUT}{$LR_BLOCK_H_R}
open: styles/Bad_Company_2_v2/template/portal/block/whois_online.html
{$C_BLOCK_H_L}<!-- IF U_VIEWONLINE --><a href="{U_VIEWONLINE}">{L_WHO_IS_ONLINE}</a><!-- ELSE -->{L_WHO_IS_ONLINE}<!-- ENDIF -->{$C_BLOCK_H_R}
{$C_BLOCK_H_L}<!-- IF U_VIEWONLINE -->{L_WHO_IS_ONLINE}<!-- ELSE -->{L_WHO_IS_ONLINE}<!-- ENDIF -->{$C_BLOCK_H_R}
nach: styles/Bad_Company_2_v2/template/portal/*.*
nach: styles/Bad_Company_2_v2/theme/images/portal/*.*
Öffne: styles/Bad_Company_2_v2/template/breadcrumbs.html
Öffne: styles/Bad_Company_2_v2/template/overall_header.html
		<td class="row1">
Öffne: styles/Bad_Company_2_v2/template/portal/block/login_box.html
Öffne: styles/Bad_Company_2_v2/template/portal/block/whois_online.html
