CA Orbital
CA Orbital
Style: CA Orbital
Style Version: 1.0.4
Style Download: http://demo.phpbb3styles.net/CA+Orbital
to: styles/ca_orbital/template/portal/*.*
to: styles/ca_orbital/theme/portal.css
to: styles/ca_orbital/theme/images/portal/*.*
open: styles/ca_orbital/template/overall_header.html
<!-- header end -->
<li class="icon-home"><!-- IF .navlinks --><span class="home-extra"><!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong> <!-- IF navlinks.S_LAST_ROW --></span><!-- ENDIF --><a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
	<div id="page-body">
open: styles/ca_orbital/template/overall_footer.html
<li class="leftside">
<!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &#187;<!-- ENDIF -->
open: styles/ca_orbital/template/portal/block/announcements_compact.html
{$C_BLOCK_H_L}
{$C_BLOCK_H_R}
{$C_BLOCK_H_L}
{$C_BLOCK_H_R}
<ul class="topiclist">
         <li class="header">
            <dl class="icon">
            </dl>
         </li>
open: styles/ca_orbital/template/portal/block/news_compact.html
{$C_BLOCK_H_L}
{$C_BLOCK_H_R}
{$C_BLOCK_H_L}
{$C_BLOCK_H_R}
			<li class="header">
				<dl class="icon">
				</dl>
			</li>
open: styles/ca_orbital/theme/stylesheet.css
open: styles/ca_orbital/theme/portal.css
background-image: url("{T_THEME_PATH}/images/portal/arrowbullet.gif");
background-image: url("{T_THEME_PATH}/images/post_show.gif");
open: styles/ca_orbital/template/portal/_block_config.html
_block_config.html for CA Orbital
nach: styles/ca_orbital/template/portal/*.*
nach: styles/ca_orbital/theme/portal.css
nach: styles/ca_orbital/theme/images/portal/*.*
Öffne styles/ca_orbital/template/overall_header.html
<!-- header end -->
Öffne: styles/ca_orbital/template/overall_footer.html
Öffne: styles/ca_orbital/template/portal/block/announcements_compact.html
{$C_BLOCK_H_L}
{$C_BLOCK_H_R}
{$C_BLOCK_H_L}
{$C_BLOCK_H_R}
         <li class="header">
            <dl class="icon">
            </dl>
         </li>
Öffne: styles/ca_orbital/template/portal/block/news_compact.html
{$C_BLOCK_H_L}
{$C_BLOCK_H_R}
{$C_BLOCK_H_L}
{$C_BLOCK_H_R}
			<li class="header">
				<dl class="icon">
				</dl>
			</li>
Öffne: styles/ca_orbital/theme/stylesheet.css
Öffne: styles/ca_orbital/theme/portal.css
Öffne: styles/ca_orbital/template/portal/_block_config.html
_block_config.html für CA Orbital
