CA Gen2
CA Gen2
Style: CA Gen2
Style Version: 1.0.9
Board3Portal Version: 1.0.5
Style Download: http://www.stsoftware.biz/phpbb30_style.ca_gen2.html
Portal Demo: http://area51.mikevil.de/portal.php?style=68
As first you need to download and install this Style. If it works, you can install the Portal for this Style as per description:
to: styles/ca_gen2/template/portal/*.*
copy: root/styles/prosilver/template/portal/block/*.*
to: styles/ca_gen2/template/portal/block/*.*
to: styles/ca_gen2/theme/portal.css
to: styles/ca_gen2/theme/images/portal/*.*
open: styles/ca_gen2/theme/stylesheet.css
find:
add after:
open: styles/ca_gen2/template/overall_header.html
find:
	<!-- header start -->
add after:
find:
	<div id="logo"><a href="{U_INDEX}"><span>{SITENAME}</span>{SITE_LOGO_IMG}</a></div>
add before:
find:
	<div id="page-header">
		<div class="navbar navbar-top">
add before:
find:
in-line find:
in-line add after:
find:
add before:
open: styles/ca_gen2/template/overall_footer.html
find:
in-line find:
               <li class="leftside">
in-line add after:
open: styles/ca_gen2/template/portal/_block_config.html
_block_config.html for ca_gen2
nach: styles/ca_gen2/template/portal/*.*
kopiere: root/styles/prosilver/template/portal/block/*.*
nach: styles/ca_gen2/template/portal/block/*.*
nach: styles/ca_gen2/theme/portal.css
nach: styles/ca_gen2/theme/images/portal/*.*
öffne: styles/ca_gen2/theme/stylesheet.css
finde:
danach einfügen:
öffne: styles/ca_gen2/template/overall_header.html
finde:
danach einfügen:
finde:
davor einfügen:
finde:
davor einfügen:
finde:
finde in dieser Zeile:
in dieser Zeile danach einfügen:
finde:
davor einfügen:
öffne: styles/ca_gen2/template/overall_footer.html
finde:
in dieser Zeile finden:
öffne: styles/ca_gen2/template/portal/_block_config.html
ersetze mit: (folge dem Link um zu dem Code zu gelangen)
_block_config.html für ca_gen2
Reason: aktuallisiert.
