Grand theft auto style help
- phpBB.de User: DJ_Marko
- phpBB.com User: DJ_Marko
hello all. i just got a great grand theft auto 4 style from phpbbhacks.com and i tryed to edit it in order to run board3portal, but with no sucess, givving me an error message when i try to open my site...
can someone help me to edit this great theme and send me the edited files or how should i edit the files and wich ones?
theme can be found here - http://www.phpbbhacks.com/download/8465
thanks in advance for any help provided
Re: Grand theft auto style help
anyone can help me with this theme? pleaseeee....
im dont know any php coding, im lost in editing the theme to make it work with the portal. please someone teach me or modify it for me.....
Should it look like this?
that looks very good mike. how can i change it to look that way?
wich style is the base for that theme? in the phpbbhacks site it doesnt say and i dont know wich source to use to edit the style
would like to use your edition if you allow me to.
Ok... the Style is based on prosilver. I didnt do something else than the instructions in install.xml and take the files for prosilver.
Since we dont provide premodded files i cant give you the whole package, but i can post my header and footer which you only have to copy into yours. Please note: If you already customiced your header/footer these changes will get lost.
overall_header.html:
overall_footer.html:
Dont forget to include portal.css in the stylesheet.css
Now you can turn on/off the Headermenu via ACP.
<head>
{META}
// <![CDATA[
var on_page = '{ON_PAGE}';
var per_page = '{PER_PAGE}';
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
var url = '{UA_POPUP_PM}';
* Find a member
function find_username(url)
return false;
window.onload = function()
eval(onload_functions[i]);
window.onunload = function()
eval(onunload_functions[i]);
</script>
</head>
<div class="outside">
<div class="top">
<div id="site-description">
<h1>{SITENAME}</h1>
<p>{SITE_DESCRIPTION}</p>
<div id="search-box">
<fieldset>
<input class="searchbutton" value="{L_SEARCH}" type="submit" /><br />
</fieldset>
</form>
<div class="inside">
<div class="bgpic">
<div class="notopgap">
<div id="wrap">
<div id="page-header">
<div class="inner">
<li class="icon-home"><!-- IF U_PORTAL --><a class="wt" href="{U_PORTAL}">{L_PORTAL}</a> » <!-- ENDIF --><a class="wt" href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>‹</strong> <a class="wt" href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
<li>
<a class="wt" href="{U_PROFILE}" title="{L_PROFILE}" accesskey="u">{L_PROFILE}</a>
<!-- IF S_DISPLAY_PM --> (<a class="wt" href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a>)<!-- ENDIF --> •
<a class="wt" href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a>
<!-- IF U_RESTORE_PERMISSIONS --> •
<a class="wt" href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a>
</li>
<li><a class="wt" href="{U_FAQ}" title="{L_FAQ_EXPLAIN}">{L_FAQ}</a> • </li>
<!-- IF not S_IS_BOT -->
<!-- IF S_DISPLAY_MEMBERLIST --><li><a class="wt" href="{U_MEMBERLIST}" title="{L_MEMBERLIST_EXPLAIN}">{L_MEMBERLIST}</a></li><!-- ENDIF -->
<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED --><li><a class="wt" href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
<li> • <a class="wt" href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="l">{L_LOGIN_LOGOUT}</a></li>
<div id="page-body">
<div id="page-footer">
<div class="inner">
<ul class="linklist">
<li class="icon-home"><!-- IF U_PORTAL --><a class="wt" href="{U_PORTAL}">{L_PORTAL}</a> » <!-- ENDIF --><a class="wt" href="{U_INDEX}" accesskey="h">{L_INDEX}</a></li>
<!-- IF S_WATCH_FORUM_LINK --><li <!-- IF S_WATCHING_FORUM -->class="icon-unsubscribe"<!-- ELSE -->class="icon-subscribe"<!-- ENDIF -->><a class="wt" href="{S_WATCH_FORUM_LINK}" title="{S_WATCH_FORUM_TITLE}">{S_WATCH_FORUM_TITLE}</a></li><!-- ENDIF -->
<!-- IF U_WATCH_TOPIC --><li <!-- IF S_WATCHING_TOPIC -->class="icon-unsubscribe"<!-- ELSE -->class="icon-subscribe"<!-- ENDIF -->><a class="wt" href="{U_WATCH_TOPIC}" title="{L_WATCH_TOPIC}">{L_WATCH_TOPIC}</a></li><!-- ENDIF -->
<!-- IF U_BOOKMARK_TOPIC --><li class="icon-bookmark"><a class="wt" href="{U_BOOKMARK_TOPIC}" title="{L_BOOKMARK_TOPIC}">{L_BOOKMARK_TOPIC}</a></li><!-- ENDIF -->
<!-- IF U_BUMP_TOPIC --><li class="icon-bump"><a class="wt" href="{U_BUMP_TOPIC}" title="{L_BUMP_TOPIC}">{L_BUMP_TOPIC}</a></li><!-- ENDIF -->
<li class="rightside"><a class="wt" href="{U_TEAM}">{L_THE_TEAM}</a> • <!-- IF not S_IS_BOT --><a class="wt" href="{U_DELETE_COOKIES}">{L_DELETE_COOKIES}</a> • <!-- ENDIF -->{S_TIMEZONE}</li>
We request you retain the full copyright notice below including the link to www.phpbb.com.
This not only gives respect to the large amount of time given freely by the developers
but also helps build interest, traffic and use of phpBB3. If you (honestly) cannot retain
the full copyright we ask you at least leave in place the "Powered by phpBB" line, with
"phpBB" linked to www.phpbb.com. If you refuse to include even this then support on our
forums may be affected.
The phpBB Group : 2006
<div class="copyright">phpBB skin developed by: <a href="http://www.jrolson.x10hosting.com/">John Olson</a><br />Powered by <a href="http://www.phpbb.com/">phpBB</a> © 2000, 2002, 2005, 2007 phpBB Group
<!-- IF TRANSLATION_INFO --><br />{TRANSLATION_INFO}<!-- ENDIF -->
<!-- IF DEBUG_OUTPUT --><br />{DEBUG_OUTPUT}<!-- ENDIF -->
<!-- IF U_ACP --><br /><strong><a href="{U_ACP}">{L_ACP}</a></strong><!-- ENDIF -->
<div>
<a id="bottom" name="bottom" accesskey="z"></a>
<!-- IF not S_IS_BOT -->{RUN_CRON_TASK}<!-- ENDIF -->
<div class="nobottomgap"></div>
<div class="bottom"></div>
</body>
</html>
thanks mike. i was in doubt because that style looks more advanced than the basic prosilver, and i dont knwo any php coding.
i will place it as soon as possible and see if i have any problem with it, hopefully it will work good:)
another issue..... do i have to copy any language files also? my site is in portuguese......
after modifying all and copy files into the site, i get this erro.....
Fatal error: in /public_html/includes/db/dbal.php on line 654
that has the following code.....
trigger_error(false, E_USER_ERROR);
how can i solve this now and make the page show?
also, i have an index.html file that has a flash intro, do i have to make any edit to amke that file show in 1st place when opening the site?
mike, big thanks for all the help. the error was due the database entries that were not made yet (forgot to run the installer lol)
it loks all good now, entry page is my flash intro, all running good, except one thing that im hoping to get help from.
its about the language, some characters proper of the portuguese language arent showing, who can help me to make portuguese characters show in the portal?
they are these kind of chars----> ç à á è é ã õ ê among others.. in the portal it shows me a question mark simbol. any way to convert this in a way to be legible in the portal?
i was editing the portal files to change the language, i used the chars directly there... do i have to use a special edit? :/
after i have it all translated, can i put the code (or files) in this site for other members from portugal (and brasil maybe) get them?
thanks again for all mike. you rock
site almost ready, time to translate the original texts of the virtual world rules and help topics from the original forums and then post in my site
i know you dont speak portuguese, but if you wanna check it go to http://www.redlightcenter-portugues.net
well, here i am again hehe.
only now i noticed a small error in the portal used for my site.
allready changed the language issue, chars are good now, but i have no clock in my portal :/
what can be the problem now?
can you help me in this one mike? hehe
Hmm... it seems the Clock is not uploaded. http://www.redlightcenter-portugues.net ... 3clock.swf
Try to upload again
May you take the Black one from here: knowledge/kb_show.php?id=20
Try to upload again
once again you are right mike. forgot to copy a folder into the style images, the 'portal' folder, with all portal icons also lol
all running great now, and also am searching for some more clocks and see if i find a good looking one for my site
thanks for all help you gave me, you are a good friend
wish i can retrieve the help someday.
