Editing the Portal's Style
Number 18
Post by Number 18 »
Your Portal Version: 1.0.2
Boardlink: http://www.seahawkshuddle.com
I would like to call different bg_list and bg_header images for my portal v. the ones call for my PHPBB board because they are too wide and cause the portal to not align.
I am not too great at writing code and was wondering how I might accomplish this.
Thanks!
japagun
phpBB.com User: japagun
Re: Calling a Different bg_list Image
Post by japagun »
just put the desire image with the same names, backup the original files....
Number 18
Post by Number 18 »
But if I replace the current image with a new one, that image will show up on my PHPBB board. I would like to use different images for the portal than for the forums.
Number 18
Post by Number 18 »
Anyone?
Maybe my question was unclear. If you look at my portal at http://www.seahawkshuddle.com/v1/portal.php, you see the blue header images (view image) and they are pushing the blocks on the right outside of where I would like them. I would like to know where in the portal sheets/styles that it calls to use this graphic. I would like to use a different graphic.
Thanks!
japagun
Re: Editing the Portal's Style
Post by japagun »
dude try to make a random banner with just one banner...see here.
http://www.phpbb.com/community/viewtopi ... 205#random
Return to “Styles Support”
