RSS Feeds Block & Scrolling Content (no iframe)?
the.ronin
Post by the.ronin »
I want to create a small block containing rss feed. Would it just be a matter of <--- Including the rss URL into the custom block html?
Thing is I want the block to be a certain height and the amount of content in the block would most certainly be a lot more than the space provided.
Can someone recommend a way to place the RSS feed into a scrollable box without having to use iframe?
ahmiquilena
phpBB.com User: amiquilena
Re: RSS Feeds Block & Scrolling Content (no iframe)?
Post by ahmiquilena »
Check my site, center block called "Proximos Raids"
http://www.lotro-latino.com/main/portal.php
I'm using:
http://www.dynamicdrive.com/dynamicinde ... roller.htm
To handle the RSS from raidplanner, and display it in a custom block, they have 2 or 3 different styles.
Very easy to install and custom :)
