Design In Progress
Show us your modified / styled Board3 Portal. We like to see what is possible with the portal... 😉
frank-bbhost
Design In Progress
Post by frank-bbhost »
Hello,
this is my attempt at modifying phpbb with board3 portal for the XN3 web-presence support grant website aimed at offering web-hosting grants for students. I used the Bl@ck theme available at bbhacks and some ajax code. Your critique is welcomed and encouraged.
Check it out at www.wsgp.org.uk
j.rhy@n
Re: Design In Progress
Post by j.rhy@n »
Blocks right site need to be moved to the left or the template made wider to allow more room for the blocks on the right, at the moment they are about 30 px wide..
Maverick
Post by Maverick »
It looks very good except for the right hand column as j.rhy@n says. Perhaps you move the one block you have there over to the left column and just have two columns?
http://www.vivaf1.com - motorsport portal
frank-bbhost
In response to Maverick and j.rhy@n: moved blocks in portal_body.html to left side for 2 column design.
I should add that the block in question had not shown up before I posted :ugeek:
Return to “Show-Off”
