Clip The Apex
Show us your modified / styled Board3 Portal. We like to see what is possible with the portal... 😉
Brogan
Clip The Apex
Post by Brogan »
We've only just installed the portal a few days ago so there's still some work to do on it but it's getting there.
We have big plans for the site so I'll post updates as and when we do them.
The portal page is here: http://www.cliptheapex.com
Steve_B
Re: Clip The Apex
Post by Steve_B »
That looks and feels very nice, you have done a great job so far...I look forward to seeing the end result :)
flat_webb
Re: Clip The Apex
Post by flat_webb »
Brogan wrote:We've only just installed the portal a few days ago so there's still some work to do on it but it's getting there.
Can I ask how you made that nice News block? Presumably it uses several rss feeds somehow? I'd very much like something similar for my portal.
Brogan
Re: Clip The Apex
Post by Brogan »
flat_webb wrote:Can I ask how you made that nice News block? Presumably it uses several rss feeds somehow? I'd very much like something similar for my portal.
It's from here: http://www.dynamicdrive.com/dynamicinde ... roller.htm
Very easy to install and configure.
flat_webb
Re: Clip The Apex
Post by flat_webb »
Thanks :) Where (i.e. what path) did you put the first piece of code and the js in? I'm not 100% sure....
Re: Clip The Apex
Beautiful.
Just a pity that you don't feel to leave any sign of a credit for our work. :(
Brogan
Re: Clip The Apex
Post by Brogan »
Beautiful.
Apologies - it's still a work in progress.
I did have the original copyright/credit info' in there but it got lost when I updated the main page and copied the overall_footer across.
I plan to create a new footer just for the portal page.
However, I can't seem to get the cookie working so I may be forced to remove the portal altogether.
Brogan
Re: Clip The Apex
Post by Brogan »
I've quickly updated the portal footer to credit this site.
Brogan
Re: Clip The Apex
Post by Brogan »
flat_webb wrote:Thanks :) Where (i.e. what path) did you put the first piece of code and the js in? I'm not 100% sure....
Missed this first time around...
The code goes in the overall_header in the <head></head> section.
I've put the js files in the /template directory and amended the path as follows:
<script type="text/javascript" src="{T_TEMPLATE_PATH}/gfeedfetcher.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/gajaxscroller.js">
Then I created a custom portal html file (e.g. news.html) and put the rss specific data in and added that file to the portal_body.html file.
Return to “Show-Off”
