Problem with install (solved)
sablehawk
Post by sablehawk »
Hi Folks,
Recently tried to install board3portal_1_0_0_rc1 and I'm having a problem.
I install phpbb 3.0.1 and get it set up, upload the board 3 portal files, manually do the changes in the install.xml and when I go to the link for the board install it tells me to click start for the install process.
Unfortunately every time I click start the screen flashes like it's going to load something and then it's right back at the start screen again.
What am I doing wrong?
Re: Problem with install
Link to your forum?
sablehawk
Post by sablehawk »
My site is at www.sanctuary57.com and the error I'm getting is
SQL ERROR [ mysqli ]
Table 'sanction_sanctuary.phpbb_portal_config' doesn't exist [1146]
I have read the other posts on the site (2 of which were completely unhelpful as they just said "I fixed it" and gave no details. I have manually edited the files, did the install in http://www.sanctuary57.com/install_portal/install.php and have gotten nowhere.
I did take a look at my phpmyadmin and do not notice there being an entry for phpbb_portal_config so I'm figuring that is the problem. Would anyone know the entries I need to put in to manually input a database entry? it's asking for # of fields, field, type, Length/Values, collation, attributes, null, default, extra and comments.
OBeer-WAN-Kenobi
Post by OBeer-WAN-Kenobi »
Hi sablehawk,
I'm no expert at all but I have sucessfully installed this portal on 3 different boards. I had this problem once and it was to do with my file edits. It was one of two things, either because I was using notepad (bad idea) or because I just plain missed something. If you use wordpad you should be allright. I've had no problems with that. I would try the file edits again on your backups and upload them fresh, then redo the install and see what happens.
Score:
OBeer = 1
Murpheys Law = 1,987
sablehawk wrote:did the install in http://www.sanctuary57.com/install_portal/install.php and have gotten nowhere.
  1. Did our installer say that the portal is successfully installed? Which message did you receive?
  2. http://www.sanctuary57.com/index.php <-- that the index page runs without a error message indicates that you don't have done all edits. In this case in the includes/constants.php. Otherwise you would get a error message on the index.php - something like "Table 'your_db.PORTAL_CONFIG_TABLE' doesn't exist."
  3. That leads me to the question: have you done all edits, as described in our install.xml - uploaded the modified files and purged the cache?
sablehawk
Post by sablehawk »
I finally got it ... for some reason using notepad was causing problems but following the suggestion OBeer-WAN-Kenobi made I used wordpad and everything worked fine.
Thanks for the suggestion Obeer :)
Re: Problem with install (solved)
Don't use Wordpad either. I recommend you use Notepad++. It is a very good and fast program with a lot of features. You can download it here: http://notepad-plus.sourceforge.net/
I do agree. ;)
Notepad++ is also good to avoid problems regarding language file formatting (UTF-8 without BOM): viewtopic.php?f=24&t=556
OBeer-WAN-Kenobi
sablehawk wrote:Thanks for the suggestion Obeer :)
No problem. I'm just glad I could actually help someone! :D
Score:
OBeer = 1
