I did all the installation, forgot to make the changes for subsilver2 before finishing the install. Deleted the install file and everything.....
Now I went ahead, made the changes for the subsilver template, and refreshed.
On my index page, it shows
"portal ---> board index"
If I click on "portal" it takes me to
"Not Found
The requested URL /portal.php was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request. "
Did I do something wrong? Do I need to move the index into the portal file?
Thank you for all your help! I am so looking forward to this!!!!!!!!!!!!!!!
portal question....did I do it right?
Re: portal question....did I do it right?
Seems like you've deleted the portal.php file. Is it present in your root directory?
I was actually just looking for it after doing some digging. It is not there. Not sure how I deleted it...I should be able to just upload that file correct?
Yes, correct.
AWESOMEAWESOMEAWESOME!!!!!!!!!!!
THANK YOU SO MUCH!!!!!!!!!!!!!!!!!!!!!!!!!
Fantastic, you're welcome!
