How to skip code from overall header
Hi, I have advertisement code in overall header file and I would like it to be skipped on portal.php. Is there any easy way how to do it?
Re: How to skip code from overall header
heres my solution.
copy the overall_header ...an rename to somethins like "portal_header"
quit the ad in that copy...
and modify the portal_body.html
<---- include overall_header jdahsndijnsa
to
<---- include portal_header sdnasoda
its a example.....just see the html files and rename.
to
No need to define a new overall_header.
Simply wrap your ads code in the overall_header with:
--- your ads code ---
Greetz
<!-- IF not $S_IN_PORTAL -->
Thanks Kevin. That's exactly what I was looking for.
