Place holders in user menu out of portal
Altered
phpBB.com User: Altered
Post by Altered »
Your Portal Version: 1.0.6
Boardlink: http://afk.site.nfoservers.com/forums
A fresh install of phpbb 3.0.8 with Reds by Culprit style added.
Searched http://www.phpbb.com/support/ searched here and Google but have found no one with the same issue
I am having trouble finding out how, or where, to fix the alignment of the USER MENU and MENU items. As you can see it has place holders are on the edge of the portal. This showed up right after install of board3 Portal.
Re: Place holders in user menu out of portal
I suppose you have the styles / your style / theme / stylesheet.css not edited.
Refresh your Styles:
Altered
Post by Altered »
Yeah tried all that I ended up going with a different style and it solved that issue. Thanks for the reply though. :mrgreen:
