Your Portal Version: 1.0.2RC3
Hey there. I'm having issues with installing the portal. I'm fine until I get to the last step which says to "Browse to install_portal/install.php and run the installer, after successfull installation delete the installer."
Our site is theoutworld.com and I have been told I need to go to "theoutworld.com/install_portal/install.php" and I get a ton of messages. You can follow the link and see the list of errors I get: http://theoutworld.com/install_portal/install.php
I have no idea how to solve this.
Running the installer
Re: Running the installer
Why are you trying to install Board3 Portal 1.0.2? The newest version is 1.0.6.
If your forum is inside your phpbb folder then, you have to put the portal there to. You can move portal.php to your main page later on, take a look at the Knowledge Base for that.
