Boardlink: http://www.chickzrule.nl
problem appeared right after installing de portal
different styles
The portal was installed a while ago (http://www.chickzrule.nl), ever since, the portal has been messy like this, but I can't find how to solve it.
Can anyone help me with this?
Thanks in advance!
Portal not showng as it should
Re: Portal not showng as it should
I am not able to access the website. Try using the search function. I guess it has something to do with your caches.
