Strange Image Problems
meevil
Post by meevil »
Your Portal Version: 1.0.6
Boardlink: http://www.nfortress.com
Installed Board 3.
Refreshing Imageset, themes and templates.
Hey guys,
I installed Board 3 with no problems so far, but I'm having a small problem with one of the image files. Namely, arrowbullet.gif
No matter what It try to do, it just won't display! Here's an image:
Re: Strange Image Problems
You've already done:
Refresh your Styles:
meevil
Post by meevil »
Done everything you've said there. It's still happening. I've even increased the width of the forum in general through common.css, thinking that might be the problem but still no luck.
Enter the forum free so I can see the portal.
A link with a closed forum, you can not see any errors.
meevil
Post by meevil »
Ok, unlocked board and made the style I'm having problems with default :)
www.nfortress.com
You have yet to add the stylesheet.css:
meevil
Post by meevil »
That did it :)
Thanks for your help!
thelecter
Post by thelecter »
Ich habe dasselbe Phänomen nur im Center des Portals. Siehe HIER. Wie bekomme ich die Aufzählungszeichen weg?
thelecter wrote:Ich habe dasselbe Phänomen nur im Center des Portals. Siehe HIER. Wie bekomme ich die Aufzählungszeichen weg?
Du bist im falschen Thema.
Board3.de - Regeln | Wir bitten um Beachtung
Wenn Du Probleme mit dem Portal hast, die einen Style betreffen, gehört das hier hin:--->Styles Support
