How to pdate from 1.0.5 to 1.0.6
Tovo
Post by Tovo »
Your Portal Version: 1.0.5
Boardlink: N/A (Locahost)
N/A
I uninstalled 1.0.5 and installed 1.0.6 with AutoMod and the mod is showing as out of date. Tried clearing the cache also.
I am trying to update my localserver version of the board from 1.0.5 to 1.0.6 before I attempt on a live website. I am having an issue with updating, I use AutoMod to install everything as im not a fan of editing files. I have tried uninstalling the 1.0.5 and installing the latest version however it still shows as out of date.
Re: How to pdate from 1.0.5 to 1.0.6
You need to run the installer.
Tovo
Post by Tovo »
And how does one run the installer ? I have tried opening the /install.xml however it gives instructions for manually editing files.
Tovo
Post by Tovo »
The next question is, how do I run the installer ?
Take a look at the bottom of install.xml.
Tovo
Post by Tovo »
I tried running the install file before but it told me it wasnt there and now it seems to work.
[SOLVED]
