Custom Global Announcement Block
trotskyicepick
Post by trotskyicepick »
Your Portal Version: 1.0.5
I want to have a custom block on my portal that just contains the one global announcement that I have created. I have checked various other posts relating to custom blocks but haven't found anything that helps. I have looked at the code for the Global Announcements block and this didn't help (this block shows normal announcements as well as global ones).
Thanks In Advance
Andrew
trotskyicepick
Re: Global Announcement Block not working
So, no ideas?
Since this block is entitled "Latest Global Announcements" it should only display global announcements. Also, I would like it to display them in order of "Last Post" not "Date Posted".
Thanks
