Php Code in Portal
edgaras85
phpBB.com User: edgaras85
Php Code in Portal
Post by edgaras85 »
I have unban system in Counter Strike here : http://www.csp.lt/unban3.php
How to make that when i go to this link it would be like in Portal in portal_center?
and would be left and right bodys and design
talonos
Portal Specialist
phpBB.com User: talonos
Re: Php Code in Portal
Post by talonos »
you could try http://www.phpbb.com/community/viewtopi ... &t=1659385 or work out how to add a custom page to phpbb. once you have the code working inside of phpbb you should be able to get portal blocks loaded using portalview
edgaras85
Post by edgaras85 »
talonos wrote:you could try http://www.phpbb.com/community/viewtopi ... &t=1659385 or work out how to add a custom page to phpbb. once you have the code working inside of phpbb you should be able to get portal blocks loaded using portalview
No thats not...
I was thinking about at begin of php code to add "include header..." "include block..."
But dont know what to include that would work...
edgaras85
Post by edgaras85 »
Bump
