Your Portal Version: 1.0.5
Boardlink: http://www.zeebobrasil.com/forum
Installed Board3 Portal on SE Square Left style
Really have no idea of what I can do, so... Nothing.
Hello there,
I'm new at phpBB forum engine and Board3 Portal, but I've managed to install both for my site.
I'm currently using Se Square Left, a prosilver-based style. When I finished to install Board3 Portal, it shows like this:
As you may see, links on right and left columns aren't fitting properly. Anyone knows why? I'd appreciate any tip.
Thanks in advance!
Menu items won't fit
Re: Menu items won't fit
Did you edit your stylesheet? Did you refresh your theme cache?
Yup. Both.
I've just noticed that this will happen even when I use prosilver "default" style. Activated it as a test for a while.
Please give me a link to your portal or activate it.
