Problem with installation
chhe123
Post by chhe123 »
Your Portal Version: 1.0.2
I've been trying to install the portal Board 3 1.0.2 and I followed all the procedures to my knowledge. I then got up to the last step where you are supposed to open the file install.php in the browser and I get the following error message displayed in the browser:
General Error
SQL ERROR [ mysqli ]
Table 'phpbb123.phpbb_portal_config' doesn't exist [1146]
SQL
SELECT config_value as version FROM phpbb_portal_config WHERE config_name = 'portal_version' LIMIT 1
BACKTRACE
FILE: includes/db/mysqli.php
LINE: 163
CALL: dbal->sql_error()
LINE: 205
FILE: includes/db/dbal.php
LINE: 170
FILE: install_portal/install.php
LINE: 51
CALL: dbal->sql_query_limit()
The error message can be seen at http://thecorpforum.com/install_portal/install.php. Does anybody know what I'm doing wrong? Any help would be appreciated.
Re: Problem with installation
Please use Board3 Portal 1.0.5. You can download it here: viewtopic.php?f=40&t=3263
pablowestenhaver89
Post by pablowestenhaver89 »
oh thank you so much! i've got the same problem too. thanks!
Being stressed out and overweight may not be YOUR fault! It's true, a mysterious condition might be to blame. An estimated 70-80% are suffering from this condition, and don't even know it!
http://www.howtocurecandida.com/survey/
