Cooperation with User reminder MOD
JirkaX
Translator
Post by JirkaX »
I'd like to add code below (from User reminder mod - http://www.phpbb.com/community/viewtopi ... &start=105) to the portal.php file, but I don't know where exactly it should be. I was told to put it before the template vars are assigned. Can anyone help me? This part of code is normally in index.php file, but now my entrance page is portal.php.
// if automatic reminders is set, remind people. lets only run this once a day.
if ( $config['user_reminder_enable'] == ENABLED )
	$check_time = gmdate('mdY',time() + (3600 * $config['board_timezone']));
	if ( $config['user_reminder_last_auto_run'] < $check_time)
		if (!function_exists('send_user_reminders'))
			include($phpbb_root_path . 'includes/functions_user_reminder.' . $phpEx);
		send_user_reminders();
		set_config('user_reminder_last_auto_run', (int) $check_time);
Re: Cooperation with User reminder MOD
The template vars are assigned here in portal.php:
$template->assign_vars(array(
	'PORTAL_LEFT_COLLUMN' 	=> $portal_config['portal_left_collumn_width'],
	'PORTAL_RIGHT_COLLUMN' 	=> $portal_config['portal_right_collumn_width'],
So you should add this code before this lines.
Let me know if it works (don't know the mod).
JirkaX
Translator
Post by JirkaX »
Thanks. I will try it and let you know. BTW That code is executed once a day only, so I will know whether it works or not tomorrow.
JirkaX
Translator
Post by JirkaX »
Tested and it seems to be working properly. Thanks for your help.
