Probier das hier mal aus:
portal_statistics_center.php
* @package Board3 Portal v2 - Statistics Center
* @ignore
if (!defined('IN_PHPBB'))
exit;
* @package Portal Statistics Center
class portal_statistics_center_module
* top 1
* left 2
* center 4
* right 8
* bottom 16
public $columns = 21;
* Default modulename
public $name = 'PORTAL_STATISTICS_CENTER';
* Default module-image:
public $image_src = 'portal_statistics.png';
* module-language file
public $language = 'portal_statistics_module';
* custom acp template
public $custom_acp_tpl = '';
global $config, $template, $user;
// Set some stats, get posts count from forums data if we... hum... retrieve all forums data
$total_posts = $config['num_posts'];
$total_topics = $config['num_topics'];
$total_users = $config['num_users'];
$total_files = $config['num_files'];
$l_total_user_s = ($total_users == 0) ? 'TOTAL_USERS_ZERO' : 'TOTAL_USERS_OTHER';
$l_total_post_s = ($total_posts == 0) ? 'TOTAL_POSTS_ZERO' : 'TOTAL_POSTS_OTHER';
$l_total_topic_s = ($total_topics == 0) ? 'TOTAL_TOPICS_ZERO' : 'TOTAL_TOPICS_OTHER';
// avarage stat
$board_days = (time() - $config['board_startdate']) / 86400;
$topics_per_day = ($total_topics) ? round($total_topics / $board_days, 0) : 0;
$posts_per_day = ($total_posts) ? round($total_posts / $board_days, 0) : 0;
$users_per_day = round($total_users / $board_days, 0);
$topics_per_user = ($total_topics) ? round($total_topics / $total_users, 0) : 0;
$posts_per_user = ($total_posts) ? round($total_posts / $total_users, 0) : 0;
$posts_per_topic = ($total_topics) ? round($total_posts / $total_topics, 0) : 0;
if ($topics_per_day > $total_topics)
$topics_per_day = $total_topics;
if ($posts_per_day > $total_posts)
$posts_per_day = $total_posts;
if ($users_per_day > $total_users)
$users_per_day = $total_users;
if ($topics_per_user > $total_topics)
$topics_per_user = $total_topics;
if ($posts_per_user > $total_posts)
$posts_per_user = $total_posts;
if ($posts_per_topic > $total_posts)
$posts_per_topic = $total_posts;
$l_topics_per_day_s = ($total_topics == 0) ? 'TOPICS_PER_DAY_ZERO' : 'TOPICS_PER_DAY_OTHER';
$l_posts_per_day_s = ($total_posts == 0) ? 'POSTS_PER_DAY_ZERO' : 'POSTS_PER_DAY_OTHER';
$l_users_per_day_s = ($total_users == 0) ? 'USERS_PER_DAY_ZERO' : 'USERS_PER_DAY_OTHER';
$l_topics_per_user_s = ($total_topics == 0) ? 'TOPICS_PER_USER_ZERO' : 'TOPICS_PER_USER_OTHER';
$l_posts_per_user_s = ($total_posts == 0) ? 'POSTS_PER_USER_ZERO' : 'POSTS_PER_USER_OTHER';
$l_posts_per_topic_s = ($total_posts == 0) ? 'POSTS_PER_TOPIC_ZERO' : 'POSTS_PER_TOPIC_OTHER';
$topics_count = $this->get_topics_count();
// Assign specific vars
$template->assign_vars(array(
'B3_TOTAL_POSTS' => sprintf($user->lang[$l_total_post_s], $total_posts),
'B3_TOTAL_TOPICS' => sprintf($user->lang[$l_total_topic_s], $total_topics),
'B3_TOTAL_USERS' => sprintf($user->lang[$l_total_user_s], $total_users),
'B3_NEWEST_USER' => sprintf($user->lang['NEWEST_USER'], get_username_string('full', $config['newest_user_id'], $config['newest_username'], $config['newest_user_colour'])),
'B3_ANNOUNCE_COUNT' => $topics_count[POST_ANNOUNCE],
'B3_STICKY_COUNT' => $topics_count[POST_STICKY],
'B3_TOTAL_ATTACH' => ($config['allow_attachments']) ? $total_files : 0,
// average stat
'B3_TOPICS_PER_DAY' => sprintf($user->lang[$l_topics_per_day_s], $topics_per_day),
'B3_POSTS_PER_DAY' => sprintf($user->lang[$l_posts_per_day_s], $posts_per_day),
'B3_USERS_PER_DAY' => sprintf($user->lang[$l_users_per_day_s], $users_per_day),
'B3_TOPICS_PER_USER' => sprintf($user->lang[$l_topics_per_user_s], $topics_per_user),
'B3_POSTS_PER_USER' => sprintf($user->lang[$l_posts_per_user_s], $posts_per_user),
'B3_POSTS_PER_TOPIC' => sprintf($user->lang[$l_posts_per_topic_s], $posts_per_topic),
return 'statistics_center.html';
return array(
'title' => 'PORTAL_STATISTICS_CENTER',
'vars' => array(),
* API functions
return true;
return true;
// Better function with only one query
public function get_topics_count()
global $db, $user;
$return_ary = array(
POST_ANNOUNCE => 0,
POST_STICKY => 0,
$sql_in = array(
POST_ANNOUNCE,
POST_STICKY,
$sql = 'SELECT DISTINCT(topic_id) AS topic_id, topic_type AS type
FROM ' . TOPICS_TABLE . '
WHERE ' . $db->sql_in_set('topic_type', $sql_in, false);
switch($row['type'])
case POST_ANNOUNCE:
++$return_ary[POST_ANNOUNCE];
break;
case POST_STICKY:
++$return_ary[POST_STICKY];
break;
$db->sql_freeresult($result);
return $return_ary;
In der
portal_statistics_module.php must du noch folgendes ergänzen
Suche nach:
Füge danach in einer neuen Zeile das hier ein:
'PORTAL_STATISTICS_CENTER' =>'Statistik',
Deine html Datei hatte auch nicht ganz gepasst:
<ul class="topiclist bg1">
<li><dl>
<dd style="border-left:0px">
<p style="margin: 0 5px 0 5px;">
{START_DATE}</p>
</dd>
</dl></li>
{$C_BLOCK_F_L}{$C_BLOCK_F_R}
So funktioniert es.
Edit:
Hatte einen Fehler bei der language Datei drin.
