Fix for login error
galante81
Fix for login error
Post by galante81 »
Hello,
When i install fix for login phpbb 3.2.7, my forum can not be loaded. No matter do i use original prosilver theme or modified, it simply does not work. I just get the message like - this page can not be loaded.. :(
Any ideas are most welcome, thank you :)
Solidjeuh
phpBB.com User: Froddelaar
Re: Fix for login error
Post by Solidjeuh »
Then you made a mistake somewhere. This package contains all fixes and updated for phpBB 3.2.7: https://www.supportforum.be/private/scripts/board3.zip
Register a free account & Play!!
~~~ https://www.solidjeuh.be ~~~
Have a secret? --> https://www.tellyoursecrets.eu
galante81
Post by galante81 »
Thank you, ill try with this package!
UPDATE: tried and as soon as i overwrite old version with this one, forum does not load at all.
lms
Post by lms »
Thank you Solidjeuh I've tried your package and it worked perfectly.
You saved me a lot of work doing all the fixes manually. I wonder why the developers do not add a package with the fixes for 3.2.x in the official release topic....
galante81:
Maybe you can try empty the forum cache;
You can also try: disabe the board; delete the old folder on .../ext/board3; install this package; enable the board again; empty cache;
Also try disabling other extensions to check if it is a compatibility problem
Good luck ;)
Solidjeuh
Post by Solidjeuh »
Clear the cache (Delete production folder in /cache)
I use this package without problems
Also try to delete ext/board3/portal folder, instead of 'overwrite the files
galante81
Post by galante81 »
Thank for advises Solidjeuh, at last i did it, BUT, for this to work i have just updated login_box_side.php file, when i try to update user_menu.php file, site crashes no matter do i clean cache or not, whatever i do... Quite strange.
What php version do you use?
galante81
Post by galante81 »
We use 7.2.20
Solidjeuh
Post by Solidjeuh »
How do you update those files? Maybe you are using a bad text editor. That can also result in "white pages" or other errors. Use notepad++ to edit your files. Also see that you don't make any mistakes in the changes you make... 1 little mistake can take your whole site offline.... ;)
galante81
Post by galante81 »
You are absolutely right Solidjeuh, but i just overwrite them, as usual.. Didn't use text editor at all :) I just downloaded files from here and overwrite my files. Quite strange only one file worked and second crashes my site :D
Solidjeuh
Post by Solidjeuh »
Have you tried deleting the board3 folder, and just upload the new files? (Disable the ext first)
galante81
Post by galante81 »
Yes i tried deleting board3 folder too, no luck. How can i disable ext, by just renaming it?
Solidjeuh
Post by Solidjeuh »
galante81 wrote: 22. July 2019 11:19 Yes i tried deleting board3 folder too, no luck. How can i disable ext, by just renaming it?
No, ACP - Customize.
Try to disable the ext, and then delete data on the same page.
Then delete board3 folder in FTP, and upload new one.
philippe
phpBB.com User: newbeetle91
Post by philippe »
Just copy the 2 files in tne archive of this post:
https://www.board3.de/viewtopic.php?f=72&t=11572
Works fine without complete reinstall
Just clear cache after
