Supernova (Base: prosilver)
Style: Supernova
Style Version: 1.0.3
Style Download: http://www.phpbb.com/community/viewtopi ... &t=2134819
to: root/styles/supernova/template/portal/*.*
to: root/styles/supernova/theme/portal.css
to: root/styles/supernova/theme/images/portal/*.*
open: root/styles/supernova/template/overall_footer.html
open: root/styles/supernova/template/overall_header.html
<div id="sn-controlbox">
</div><!-- /sn-controlbox -->
<div id="sn-navbar">
<div id="sn-navbar-content">
</div><!-- /sn-navbar-content -->
</div><!-- /sn-navbar -->
<div id="sn-shadows">
<div class="sn-options <!-- IF SCRIPT_NAME eq 'index' or 'viewforum' -->sn-search-links<!-- ENDIF --><!-- IF SCRIPT_NAME eq 'viewtopic' -->sn-restore-link-size<!-- ENDIF -->">
open: root/styles/supernova/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
open: root/styles/supernova/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
open: root/styles/supernova/template/portal/modules/login_box_side.html
{$LR_BLOCK_H_L}<a href="{U_LOGIN_LOGOUT}"><!-- IF $S_BLOCK_ICON --><img src="{$IMAGE_SRC}" width="{$IMAGE_WIDTH}" height="{$IMAGE_HEIGHT}" alt="" />&nbsp;<!-- ENDIF -->{$TITLE}</a>{$LR_BLOCK_H_R}
open: root/styles/supernova/template/portal/modules/whois_online_center.html
{$C_BLOCK_H_L}<!-- IF U_VIEWONLINE --><a href="{U_VIEWONLINE}">{$TITLE}</a><!-- ELSE -->{$TITLE}<!-- ENDIF -->{$C_BLOCK_H_R}
{$C_BLOCK_H_L}<!-- IF U_VIEWONLINE -->{$TITLE}<!-- ELSE -->{$TITLE}<!-- ENDIF -->{$C_BLOCK_H_R}
open: root/styles/supernova/template/portal/modules/whois_online_side.html
{$LR_BLOCK_H_L}<!-- IF $S_BLOCK_ICON --><img src="{$IMAGE_SRC}" width="{$IMAGE_WIDTH}" height="{$IMAGE_HEIGHT}" alt="" />&nbsp;<!-- ENDIF --><!-- IF U_VIEWONLINE --><a href="{U_VIEWONLINE}">{$TITLE}</a><!-- ELSE -->{$TITLE}<!-- ENDIF -->{$LR_BLOCK_H_R}
{$LR_BLOCK_H_L}<!-- IF $S_BLOCK_ICON --><img src="{$IMAGE_SRC}" width="{$IMAGE_WIDTH}" height="{$IMAGE_HEIGHT}" alt="" />&nbsp;<!-- ENDIF --><!-- IF U_VIEWONLINE -->{$TITLE}<!-- ELSE -->{$TITLE}<!-- ENDIF -->{$LR_BLOCK_H_R}
open: root/styles/supernova/theme/stylesheet.css
open: root/styles/supernova/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dd style="float: left; margin: -2px 0px 0px -4px; height: 23px;"><div class="cat-name"><span>' -->
<!-- DEFINE $LR_BLOCK_H_R = '</span></div></dd></dl></li></ul><div class="panel bg1" style="padding:4px; margin: 0px 0px 0px 0px;">' -->
<!-- DEFINE $LR_BLOCK_F_L = '</div>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dd style="float: left; margin: -2px 0px 0px -4px; height: 23px;"><div class="cat-name"><span>' -->
<!-- DEFINE $C_BLOCK_H_R = '</span></div></dd></dl></li></ul><div class="panel bg1" style="padding:4px; margin: 0px 0px 0px 0px;">' -->
<!-- DEFINE $C_BLOCK_F_L = '</div>' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon"><dd style="float: left; margin: -2px 0px 0px -4px; height: 23px;"><div class="cat-name"><span>' -->
<!-- DEFINE $CC_BLOCK_H_R = '</span></div></dd></dl></li></ul><div class="panel bg1" style="padding:4px; margin: 0px 0px 0px 0px;">' -->
<!-- DEFINE $S_POSTBODY_TOP = 0 -->
nach: root/styles/supernova/template/portal/*.*
nach: root/styles/supernova/theme/portal.css
nach: root/styles/supernova/theme/images/portal/*.*
Öffne: root/styles/supernova/template/overall_footer.html
Öffne: root/styles/supernova/template/overall_header.html
Öffne: root/styles/supernova/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
Öffne: root/styles/supernova/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
Öffne: root/styles/supernova/template/portal/modules/login_box_side.html
Öffne: root/styles/supernova/template/portal/modules/whois_online_center.html
Öffne: root/styles/supernova/template/portal/modules/whois_online_side.html
Öffne: root/styles/supernova/theme/stylesheet.css
Öffne: root/styles/supernova/template/portal/_block_config.html
