Absolution (Base: prosilver)
Style: Absolution
Style Version: 1.1
Style Download: http://www.christianbullock.com/2012/ab ... -available
to: root/styles/absolution/template/portal/*.*
to: root/styles/absolution/theme/portal.css
to: root/styles/absolution/theme/images/portal/*.*
open: root/styles/absolution/template/navbar.html
            <li<!-- IF SCRIPT_NAME eq 'index' --> class="active"<!-- ENDIF -->>
                <a href="{U_INDEX}"><img src="{T_THEME_PATH}/images/nav-home.png" width="16" height="16" alt="" />{L_INDEX}</a>
            </li>
            <li class="divider"></li>
		<!-- IF U_PORTAL -->
            <li<!-- IF SCRIPT_NAME eq 'portal' --> class="active"<!-- ENDIF -->>
                <a href="{U_PORTAL}"><img src="{T_THEME_PATH}/images/nav-home.png" width="16" height="16" alt="" />{L_PORTAL}</a>
            </li>
open: root/styles/absolution/template/overall_header.html
<!-- INCLUDE navbar.html -->
open: root/styles/absolution/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
open: root/styles/absolution/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
open: root/styles/absolution/theme/stylesheet.css
@import url("absolution.css");
open: root/styles/absolution/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div class="catglow"><div class="cathead-m"><div class="cathead-r"><div class="cathead-l" style="min-width: 180px; border-radius: 5px 5px 3px 3px;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</div></div></div><div class="collapsethis">' -->
<!-- DEFINE $LR_BLOCK_F_R = '</div></div><br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="catglow"><div class="cathead-m"><div class="cathead-r"><div class="cathead-l">' -->
<!-- DEFINE $C_BLOCK_H_R = '</div></div></div><div class="collapsethis">' -->
<!-- DEFINE $C_BLOCK_F_R = '</div></div><br style="clear:both" />' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="catglow"><div class="cathead-m"><div class="cathead-r"><div class="cathead-l">' -->
<!-- DEFINE $CC_BLOCK_H_R = '</div></div></div><div class="collapsethis">' -->
<!-- DEFINE $BLOCK_DISTANCE = '17px' -->
<!-- DEFINE $S_POSTBODY_TOP = 0 -->
nach: root/styles/absolution/template/portal/*.*
nach: root/styles/absolution/theme/portal.css
nach: root/styles/absolution/theme/images/portal/*.*
Öffne: root/styles/absolution/template/navbar.html
            </li>
            </li>
Öffne: root/styles/absolution/template/overall_header.html
Öffne: root/styles/absolution/template/portal/modules/announcements_center_compact.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
Öffne: root/styles/absolution/template/portal/modules/news_compact_center.html
{$CC_BLOCK_H_L}
{$CC_BLOCK_H_R}
{$CC_BLOCK_H_L}
	{$TITLE}
{$CC_BLOCK_H_R}
Öffne: root/styles/absolution/theme/stylesheet.css
Öffne: root/styles/absolution/template/portal/_block_config.html
