utf8_strpos: Offset must be an integer
Current Version: 2.0.2
Released: 2013-10-27
yoper
Post by yoper »
Hello,
I'm not sure what I did, the portal was working just fine but now when I access to the portal I get this error:
General Error
What can cause this error?
Also another question, what is the use of board3_menu"_1"? can't it just be board3_menu?
Edit:I changed this line in includes/utf/utf_tools.php so I can get errors
trigger_error('utf8_strpos: Offset must be an integer', E_USER_ERROR);
to
here is what I get:
[phpBB Debug] PHP Notice: in file /includes/utf/utf_tools.php on line 310: Invalid error type specified
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4319: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4321: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4322: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4323: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)
Re: utf8_strpos: Offset must be an integer
That error appears because you changed that line.
We are already aware of the mentioned bug and we are currently working on it.
yoper
Post by yoper »
Thanks for your answer Marc, I will be waiting for the fix.
Thanks for the great work. ;)
yoper
Post by yoper »
Hello,
I tried to move up "Link to us" but it stuck and can't pass "Top Posters"
Also are you close from finding "utf8_strpos: Offset must be an integer" error?
Regards.
yoper
Post by yoper »
Update
This will help you fixing the problem:
When I removed the Latest news module also Global announcements can cause that, the error doesn't show anymore ;) (Offset must be an integer)
stesmi
Post by stesmi »
Hi all.
I know, first post and all.
I put in a debug_print_backtrace() into utf8_strpos where they print the failure message and found that utf8_strpos is being called with an empty last argument (or well, it's "false" so it doesn't print as anything).
That comes from the following line in bbcodes.php:317
while (($last_html_opening = utf8_strpos($content, '<', $last_html_closing)) !== false)
The line before that is :
$last_html_opening = $last_html_closing = $last_smiley = false;
Making $last_html_closing FALSE. and FALSE isn't a number.
I changed the = false to = 0 and voilá, it works.
I don't know if it's a proper fix or so but it seems to make it work here.
So line 316, change = false to = 0 until the devs tell us otherwise I guess?
// Stefan
giardiniere
Post by giardiniere »
Any news?
stesmi
Post by stesmi »
My fix not working for you ?
// Stefan
giardiniere
I have not tried it because I have to decide to install 2.0 version and I wanted to know if this bug is officially fixed :oops:
Thank you for your help :) but I'd like to know if your solution is "the solution" for Marc too ;-)
George
phpBB.de User: George
phpBB.com User: George
Post by George »
yoper wrote:Update
Hey guys, I'm also having this issue.
I removed those two modules and now receive a blank page on the portal. When I put the modules back, I receive the same blank page.
stesmi wrote:Hi all.
// Stefan
I tried this, but I wasn't able to find the line of code.
Any help is appreciated, I really want this MOD to work.
