Style Version: 1.0.1
Style Download: http://demo.phpbb3styles.net/Attriuum
to: styles/Attriuum/template/portal/*.*
to: styles/Attriuum/theme/portal.css
to: styles/Attriuum/theme/images/portal/*.*
open: styles/Attriuum/template/overall_header.html
<li class="chosen"><a href="{U_INDEX}">{L_INDEX}<br /><span>{L_INDEX}</span></a><ul>
<li class="chosen"><a href="{U_PORTAL}">{L_PORTAL}<br /><span>{L_PORTAL}</span></a></li>
<li class="icon-home"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>‹</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
FindCode: Select all
Tip: Add these lines on a new blank line before the preceding line(s) to find.open: styles/Attriuum/template/overall_footer.htmlCode: Select all
open: styles/Attriuum/theme/stylesheet.cssCode: Select all
Tip: Add these lines on a new blank line after the preceding line(s) to find.open: styles/Attriuum/template/portal/_block_config.htmlCode: Select all
_block_config.html for 1thank_red / 1thank_green / 1thank / Attriuum
nach: styles/Attriuum/template/portal/*.*
nach: styles/Attriuum/theme/portal.css
nach: styles/Attriuum/theme/images/portal/*.*
Öffne: styles/Attriuum/template/overall_header.html
FindenCode: Select all
Hinweis: Diese Zeile(n) werden in einer neuen Zeile vor den/der gerade gesuchten eingefügt.Öffne: styles/Attriuum/template/overall_footer.htmlCode: Select all
Öffne: styles/Attriuum/theme/stylesheet.cssCode: Select all
Hinweis: Diese Zeile(n) werden in einer neuen Zeile nach den/der gerade gesuchten eingefügt.Öffne: styles/Attriuum/template/portal/_block_config.htmlCode: Select all
_block_config.html für 1thank_red / 1thank_green / 1thank / Attriuum
