Style-Version: 1.0.14
phpBB-Version: 3.0.7
Style Download: http://www.gamexe.net/forum/viewtopic.p ... f=1&t=1241
- [+] ENGLISH
to: styles/610nm/template/portal/*.*
to: styles/610nm/theme/images/portal/*.*
open: styles/610nm/template/breadcrumbs.html
<li class="icon-home"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>‹</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
Tip: This is a partial match of a line for in-line operations.In-line Add beforeCode: Select all
open: styles/610nm/template/overall_header.htmlCode: Select all
<div id="wrapheader">
<div id="wrapcentre">
Tip: Add these lines on a new blank line before the preceding line(s) to find.open: styles/610nm/template/portal/_block_config.htmlCode: Select all
_block_config.html for 610nm
- [+] DEUTSCH
Kopiere: root/styles/subsilver2/template/portal/*.*
nach: styles/610nm/template/portal/*.*
Kopiere: root/styles/subsilver2/theme/images/portal/*.*
nach: styles/610nm/theme/images/portal/*.*
Öffne: styles/610nm/template/breadcrumbs.html
Hinweis: Dies ist ein Ausschnitt einer Zeile für Änderungen innerhalb einer Zeile.In der Zeile davor einfügenCode: Select all
Öffne: styles/610nm/template/overall_header.htmlCode: Select all
Hinweis: Diese Zeile(n) werden in einer neuen Zeile vor den/der gerade gesuchten eingefügt.Öffne: styles/610nm/template/portal/_block_config.htmlCode: Select all
_block_config.html für 610nm
