Style Version: 1.3.7a
phpBB Version: 3.0.7-PL!
Board3Portal Version: 1.0.5
Style Download: http://www.phpbbhq.com/?p=16
Portal Demo: http://area51.mikevil.de/portal.php?style=85
- This Guide is written for AeroRed, but it works for AeroBlack, AeroGreen and AeroBlue also. If you want to use this Guide for ..Black ..Green or ..Blue you just have to replace "AeroRed" with the Name of your Style in this Guide.
As first you need to download and install this Style. If it works, you can install the Portal for this Style as per description:
to: styles/AeroRed/template/portal/*.*
to: styles/AeroRed/theme/images/portal/*.*
open: styles/AeroRed/template/breadcrumbs.html
find:in-line find:Code: Select all
<p class="breadcrumbs"><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> » <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>
in-line add after:Code: Select all
open: styles/AeroRed/template/overall_header.html
find:add before:Code: Select all
<table width="100%" border="0" align="center" cellpadding="0" cellspacing="0"> <tr> <td height="24" style="background: #06518A url('{T_THEME_PATH}/images/navbarbg.png') no-repeat right top;"> <div id="navbarbg"> <span class="buttonwrapper">
</td> <td width="18" style="background:url('{T_THEME_PATH}/images/mr.png');"></td> </tr> <tr> <td width="18" height="18"><img src="{T_THEME_PATH}/images/bl.png" width="18" height="18" alt="" /></td> <td height="18" style="background:url('{T_THEME_PATH}/images/bm.png');"></td> <td width="18" height="18"><img src="{T_THEME_PATH}/images/br.png" width="18" height="18" alt="" /></td> </tr> </table> </div>
<div id="datebar">
<br style="clear: both;" /> <!-- INCLUDE breadcrumbs.html --> <br />
open: styles/AeroRed/template/portal/_block_config.html
replace with: (choose your Style)
AeroRed
AeroGreen
AeroBlack
AeroBlue
- Diese Anleitung wurde für AeroRed geschrieben, funktioniert aber auch für AeroBlack, AeroGreen und AeroBlue.
Wenn ihr diese Anleitung für ..Black ..Green oder ..Blue nutzen wollt, müsst ihr einfach "AeroRed" in diese Anleitung mit dem Namen eures Styles ersetzen.
nach: styles/AeroRed/template/portal/*.*
nach: styles/AeroRed/theme/images/portal/*.*
öffne: styles/AeroRed/template/breadcrumbs.html
finde:finde in dieser Zeile:Code: Select all
füge in diese Zeile danach ein:Code: Select all
öffne: styles/AeroRed/template/overall_header.html
finde:füge davor ein:Code: Select all
finde:Code: Select all
<div id="datebar">
füge danach ein:Code: Select all
öffne: styles/AeroRed/template/portal/_block_config.html
ersetze durch: (wähle dein Style)
AeroRed
AeroGreen
AeroBlack
AeroBlue
