_block_config.html
<!--version $Id: _block_config.html 553 adapted by: Mike $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<ul class="outer-cat"><li class="top-cat"><dl class="cat-container"><dd class="cat-left" style="width: 20px; text-indent:15px;"><ul style="list-style-type:none;"><li><dl><dd>' -->
<!-- DEFINE $LR_BLOCK_H_R = '</dd></dl></li></ul></dd><dd class="cat-text"></dd><dd class="cat-right" style="width: 20px;"></dd></dl></li></ul><div class="panel bg3" style="padding:5px 10px 0;">' -->
<!-- DEFINE $LR_BLOCK_F_R = '<span class="corners-bottom"><span></span></span></div><br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<ul class="outer-cat"><li class="top-cat"><dl class="cat-container"><dd class="cat-left"><ul style="list-style-type:none;"><li><dl>' -->
<!-- DEFINE $C_BLOCK_H_R = '</dl></li></ul></dd><dd class="cat-text"></dd><dd class="cat-right" style="width: 20px;"></dd></dl></li></ul><div class="panel bg3" style="padding:5px 10px 0;">' -->
<!-- DEFINE $C_BLOCK_F_R = '<span class="corners-bottom"><span></span></span></div><br style="clear:both" />' -->
no
