Your Portal Version: 2.0.0
nothing
look at the gallery_centre.html for SN
clcik here to see the problem in Supernova
in Supernova it is a fixed width - around 900 I think, this causes a problem not encountered on floating width styles like subSilver2 or prosilver
the problem is a) that the Gallery_Centre body is TOO WIDE - maybe reducing the images from 3 to 2, OR reducing the image width to 60% would solve it
B) in the mChat body the SN styling is missing
Has anyone already enstalled Supernova Portal AND used mChat centre and/or Gallery centre?
Supernova
Re: Supernova
You must not insert the block in the middle, they can also insert the block up or down.
And they see here: viewtopic.php?f=54&t=4914&p=30545#p30436
