phpBB Calendar block on Board3 Portal (Update 1.0.4)
wang5555
Translator
phpBB.com User: wang5555
Post by wang5555 »
About this MOD:
Title:phpBB Calendar block on Board3 Portal
Description:Adds a phpBB Calendar block (not mini calendar block by default) to your forum on Board3 Portal.
Version:1.0.4
Installation Level:Easy
Installation Time:~5 minutes
Author Notes:This is not a official MOD.
Essential condition--Your forum already install two mods following:
1. Board3 Portal 1.0.4
http://www.phpbb.com/community/viewtopi ... &t=1179085
2. phpBB Calendar 0.1.0 (alightner)
http://www.phpbb.com/community/viewtopi ... 0&t=666195
History:
2008-12-28 - Version1.0.0
-Release of version 1.0.0.
2009-02-10 - Version1.0.1
-Fixed Timezone bug
-Fixed if ACP set "Display Next Events" will appear wrong
-Added one language variable
-Updated MODX 1.2.2 format
2009-05-20 - Version1.0.2
-Fixed calendar.php bug
-Changed calendar.html and calendar_2.html codes cooperated with "Board3 Portal" mod update 1.0.3
2009-07-29 - Version1.0.3
-Cooperated with original "phpBB Calendar" mod update 0.1.0
2009-12-18 - Version1.0.4
-Cooperated with original "Board3 Portal" mod update 1.0.4
-Updated MODX 1.2.3 format
Download:
phpBB_Calendar_block_on_Board3_Portal_104.zip
P.S.
1.0.3 to 1.0.4:
No file needs to change.
It is more blessed to give than to reveive, welcome to letter, thanks & good-bye!
Good luck ^_^
Welcome to visit my forum!!
https://wang5555.dnsfor.me/phpBB3/
p.s. Shut down computer before 11 clock night!!!
wang5555
Translator
Re: [Mod] phpBB Calendar block on Board3 Portal
Post by wang5555 »
The known issue -- "Timezone" error.
viewtopic.php?p=9696#p9696
Good luck ^_^
wang5555
Translator
Post by wang5555 »
Update v1.0.1,
See first post.
Good luck ^_^
Razer
Post by Razer »
I have a problem with this mod. In the install.xml I have to edit the includes/functions_calendar.php, but I haven't one!
What I can do?
wang5555
Translator
Post by wang5555 »
Razer wrote:I have a problem with this mod. In the install.xml I have to edit the includes/functions_calendar.php, but I haven't one!
What I can do?
See first post "Author Notes".
Good luck ^_^
wang5555
Translator
Re: phpBB Calendar block on Board3 Portal (Update 1.0.2)
Post by wang5555 »
Update v1.0.2,
See first post.
Good luck ^_^
Maybe the Versions Numbers could be al little bit confusing... ;)
sitwi
phpBB.com User: sitwi
Post by sitwi »
One little question for this, please - the list of mini-events on the portal displays dates in the American format, i.e. 25th July = 7/25.
Can someone tell me how to reverse this to display as 25/7, please?
Thanks. :)
Tobal
Post by Tobal »
Hey!Thanks for the mod.
I installed it, but it gives me this error message in my portal:
Error General
Language file ./language/es_ar/mods/calendar.php couldn't be opened.
Could it be because I don't use the "En" default language?
I installed it in my "es_ar" language, because I don't use "En"
Please help. :(
You need to copy the language files also to your language directory.
More information:
Knowledge Base: Solution: Language file xyz.php couldn't be opened!
sitwi
Post by sitwi »
sitwi wrote:One little question for this, please - the list of mini-events on the portal displays dates in the American format, i.e. 25th July = 7/25.
Thanks. :)
Sorry to repeat - any help for this, please?
hmm
phpBB.de User: hmm
phpBB.com User: hmm
Post by hmm »
Thanks for this!
Work fine ! But... how I can edit my events? :lol:
Other question:
My block of calendar is:
But I want it like this:
And the last..
I did the translation to Portuguese of the calendar, but the mini calendar how i change Su, Mo, etc. (weekdays) for D, S, etc. (in Portuguese)?
I did .. But in a way wrong, because I moved on page calendar.html and calendar2.html
And .. What is the difference between the two pages?
Thanks, and sorry my english!
wang5555
Translator
Post by wang5555 »
Thanks. :)
Try it:
--OPEN--
--FIND--
            //$event_output['NUMBER'] = $dayOfEvent["mday"].".".$dayOfEvent["mon"].".";
            $event_output['NUMBER'] = $dayOfEvent["mon"].".".$dayOfEvent["mday"]."";
--REPLACE WITH--
--SAVE % CLOSE--
Good luck ^_^
wang5555
Translator
Post by wang5555 »
hmm wrote:Thanks for this!
Edit your events In phpBB Calendar.
hmm wrote: Other question:
Must mend some files following:
styles/YOUR_STYLE/template/portal/block/calendar.html
styles/YOUR_STYLE/template/portal/block/calendar2.html
hmm wrote: And the last..
If your phpBB Calendar display with "week", use "calendar.html";
Elseif your phpBB Calendar display with "next events", use "calendar2.html".
Good luck ^_^
sitwi
Post by sitwi »
wang5555 wrote: Try it:
--OPEN--
--FIND--
--REPLACE WITH--
--SAVE % CLOSE--
Thanks; makes perfect sense now that I look at it, and I've no idea why it doesn't work, but it doesn't! I've purged everything. :?:
Just to be clear, it's the text on the calendar block itself, within the portal, that I'd like to change.
Thanks again.
